storage tape config-file get
Get a tape drive configuration file
The storage tape config-file get command uploads a specified tape drive configuration file to each node that is currently part of the cluster.
-url <text>- Config File URL-
This parameter specifies the URL that provides the location of the package to be fetched. Standard URL schemes, including HTTP and TFTP, are accepted.
The following example uploads the specified tape drive configuration file to each node that is currently part of the cluster:
cluster1::> storage tape config-file get -url http://example.com/~tapeconfigfile/XYZ_LTO-6.TCF
