ONTAP commands
storage tape reset
Reset a tape drive
This command resets a specified tape drive.
-node {<nodename>|local} - Node (privilege: advanced)
Use this parameter to specify the node to which the tape drive is attached.
-device-id <text> - Tape Drive Device ID (privilege: advanced)
Use this parameter to specify the device ID of the tape drive is to be reset.
The following example resets the tape drive with device ID sw4:2.126L3 attached to the node, cluster1-01.
cluster1::> storage tape reset -node cluster1-01 -device-id sw4:2.126L3
