system configuration backup download
Download a configuration backup
The system configuration backup download command copies a configuration backup from a source URL to a node in the cluster.
-node {<nodename>|local}- Node (privilege: advanced)-
Use this parameter to specify the name of the node to which the configuration backup is downloaded.
-source <text>- Source URL (privilege: advanced)-
Use this parameter to specify the source URL of the configuration backup to download.
[-backup-name <text>]- Backup Name (privilege: advanced)-
Use this parameter to specify a new local file name for the downloaded configuration backup.
[-validate-certificate {true|false}]- Validate Digital Certificate (privilege: advanced)-
Use this parameter with the value
trueto validate the digital certificate of the remote server.
The following example shows how to download a configuration backup file from a URL to a file named exampleconfig.download.7z on the node node2 .
cluster1::*> system configuration backup download -node node2 -source http://www.example.com/config/download/nodeconfig.7z -backup-name exampleconfig.download.7z
