system controller config pci show-hierarchy
Display PCI hierarchy
The system controller config pci show-hierarchy command displays the PCI Hierarchy of all PCI devices found in a controller. The command displays the following information about the PCI devices:
Node
Level
Device
Link Capability
Link Status
To display more details, use the -instance parameter.
- { [-fields <fieldname>,…]
Selects the fields that you specify.
- | [-instance ]}
Displays detailed information for PCI devices.
- [-node {<nodename>|local}]- Node
Displays the PCI hierarchy of the specified node.
- [-level <integer>]- PCI Device Level
Displays the PCI devices that match the specified level within the PCI hierarchy.
- [-pci-device <text>]- PCI Device
Displays the PCI devices that match the specified device description.
- [-link-cap <text>]- Link Capability
Displays the PCI devices that match the specified link capability.
- [-link-status <text>]- Link Status
Displays the PCI devices that match the specified link status.
The example below displays the PCI hierarchy for all of the nodes in the cluster.
cluster1::> system controller config pci show-hierarchy
PCI Hierarchy
Node: cluster1-01
Level Device    Link
1     Br[3721](0,3,0): PCI Device 8086:3721 on Controller
                LinkCap(MaxLkSp(2),MaxLkWd(4),ASPM(3),L0(3),L1(6),Port(68))
                LinkStatus(LkSp(2),LkWd(4),DLAct),
2     Dv[8001](1,0,0): PMC SAS adapter on Controller
                LinkCap(MaxLkSp(2),MaxLkWd(8),ASPM(3),L0(3),L1(6),Port(68))
                LinkStatus(LkSp(2),LkWd(4),SClk),
1     Br[3722](0,4,0): PCI Device 8086:3722 on Controller
                LinkStatus(LkSp(1),LkWd(4),DLAct),
2     Dv[6274](2,0,0): PCI Device 15b3:6274 on Controller
                LinkCap(MaxLkSp(1),MaxLkWd(8),ASPM(1),L0(7),L1(7),Port(68))
                LinkStatus(LkSp(1),LkWd(4)),
1     Br[3723](0,5,0): PCI Device 8086:3723 on Controller
                LinkStatus(LkSp(1),LkWd(0)),
1     Br[3b42](0,28,0): PCI Device 8086:3b42 on Controller
                LinkCap(MaxLkSp(1),MaxLkWd(4),ASPM(3),L0(4),L1(6),Port(68))
                LinkStatus(LkSp(1),LkWd(4),SClk,DLAct),
2     Dv[150e](4,0,0): Intel 1G NIC on Controller
                LinkCap(MaxLkSp(2),MaxLkWd(4),ASPM(3),L0(6),L1(6),Port(68))
                LinkStatus(LkSp(1),LkWd(4),SClk),
2     Dv[150e](4,0,1): Intel 1G NIC on Controller
2     Dv[150e](4,0,2): Intel 1G NIC on Controller
2     Dv[150e](4,0,3): Intel 1G NIC on Controller
1     Br[3b4a](0,28,4): PCI Device 8086:3b4a on Controller
                LinkCap(MaxLkSp(1),MaxLkWd(1),ASPM(3),L0(4),L1(6),Port(68))
                LinkStatus(LkSp(1),LkWd(1),SClk,DLAct),
2     Dv[10d3](5,0,0): Intel 1G NIC on Controller
                LinkCap(MaxLkSp(1),MaxLkWd(1),ASPM(3),L0(1),L1(6),Port(68))
                LinkStatus(LkSp(1),LkWd(1),SClk),
1     Br[3b4e](0,28,6): PCI Device 8086:3b4e on Controller
2     Dv[10d3](7,0,0): Intel 1G NIC on Controller
Node: cluster1-02
Level Device    Link
28 entries were displayed.
cluster::>
 PDFs
PDFs
