ONTAP commands
system controller service-event delete
Manually clear a selected service event
The system controller service-event delete command removes the service event from the list and extinguishes all related FRU attention LEDs.
In some cases, where the underlying fault condition remains, the service event might be reported again, causing it to reappear in the list. In such cases, it is necessary to remedy the underlying fault condition in order to clear the service event.
-node {<nodename>|local} - Node
Selects service events on the specified nodes.
-event-id <integer> - Service Event ID
Selects the service events that match the specified event identifier. Together with the node, this field uniquely identifies the row to delete. Use the system controller service-event show command to find the event identifier for the service event to delete.
The following example lists the currently active service events. Then, using the listed Service Event ID, the service event is deleted:
cluster1::> system controller service-event show
Node             ID  Event Location                      Event Description
plata4-1a        1   DIMM in slot 1 on Controller A      Uncorrectable ECC
cluster1::> system controller service-event delete -event-id 1
