ONTAP commands
system ha interconnect ood disable-statistics
Disable detailed statistics collection
The system ha interconnect ood disable-statistics command disables collection of the statistics on the out-of-order delivery-capable high-availability interconnect device. This command is only supported on FAS2500 series nodes in the cluster.
-node <nodename> - Node (privilege: advanced)
This mandatory parameter specifies which node will have the statistics collection disabled. The value "local" specifies the current node.
cluster1::*> system ha interconnect ood disable-statistics -node ic-f2554-03
