ONTAP commands
system node autosupport invoke-performance-archive
Generate and send an AutoSupport message with performance archives.
The system node autosupport invoke-performance-archive command sends an AutoSupport message with the performance archives from a node. The command requires that the performance archives in the specified date range be present while the AutoSupport message is being transmitted.
Note Performance archive upload is not supported when the -remove-private-data parameter is enabled. To disable this parameter, use the system node autosupport modify -remove-private-data false command.
-node {<nodename>|local} - Node
Use this parameter to specify the node from which the AutoSupport message is sent. The default setting is localhost.
[-message <text>] - Message Included in the AutoSupport Subject
Use this parameter to specify the text in the subject line of the AutoSupport message.
[-uri <text>] - Alternate Destination for This AutoSupport
Use this parameter to send the AutoSupport message to an alternate destination. Only "file" and "https" protocols are supported. If this parameter is omitted, the message is sent to the all of the recipients defined by the system node autosupport modify command.
[-force <true>] - Generate and Send Even if Disabled
Use this parameter to generate and send the AutoSupport message even if AutoSupport is disabled on the node.
[-case-number <text>] - Case Number for This Performance Archive Upload
Use this parameter to specify the optional case number to be associated with this AutoSupport message.
-start-date <MM/DD/YYYY HH:MM:SS> - Start Date for Performance Archive Dataset
Use this parameter to specify the start date for the files in the performance archive dataset to be included in the AutoSupport message.
{ -end-date <MM/DD/YYYY HH:MM:SS> - End Date for Performance Archive Dataset
Use this parameter to specify the end date for the files in the performance archive dataset to be included in the AutoSupport message. The end date should be within six hours of the start date.
| -duration <[<integer>h][<integer>m][<integer>s]> - Duration of Performance Archive Dataset }
Use this parameter with start-date to specify the duration of the performance archive dataset to be included in the AutoSupport message. The maximum duration limit is six hours from the start date.
Use this command to invoke an AutoSupport message to include the performance archives in the given date range:
cluster1::> system node autosupport invoke-performance-archive -node local -start-date 9/12/2013 19:37:24 -end-date 9/12/2013 22:37:24
cluster1::> system node autosupport invoke-performance-archive -node local -start-date 11/21/2013 13:42:09 -duration 6h
