system node environment sensors show
Display the sensor table
The system node environment sensors show command displays the following information:
Node name
Sensor name
Sensor state
Sensor value
Sensor units
Critically Low threshold for the sensor
Warning Low threshold for sensor
Warning High threshold for sensor
Critically High threshold for the sensor
FRU name (detailed view only)
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node-
Selects information about the sensors on the specified node.If this parameter is specified with the -name parameter, the command displays information only about the specified sensor.
[-name <text>]- Sensor Name-
Selects information about the sensors that have the specified name.If this parameter is specified with the -node parameter, the command displays information only about the specified sensor.
[-fru <text>]- FRU-
Selects information about the sensors associated with the specified Field Replaceable Unit (FRU).
[-type {fan|thermal|voltage|current|battery-life|discrete|fru|nvmem|counter|minutes|percent|agent|unknown}]- Sensor Type-
Selects information about the sensors that have the specified sensor type. Possible values vary among platforms but may include
fan,temperature,thermalandvoltage. [-units <text>]- Value Units-
Selects information about the sensors that have readings displayed in the specified units of measure. Possible values vary among platforms but may include
RPM,CandmV. [-state {normal|warn-low|warn-high|crit-low|crit-high|disabled|uninitialized|init-failed|not-available|invalid|retry|bad|not-present|failed|ignored|fault|unknown|nonreadable}]- Sensor State-
Selects information about the sensors that have the specified state. Possible values vary among platforms but may include
normal,warn_lo,warn_hi,crit_lo,crit_hiandfailed. [-discrete-state {normal|warn-low|warn-high|crit-low|crit-high|disabled|uninitialized|init-failed|not-available|invalid|retry|bad|not-present|failed|ignored|fault|unknown|nonreadable}]- Discrete Sensor State-
Selects information about the discrete-valued sensors that are in the specified state. A discrete-valued sensor has a set of possible discrete values rather than a range of possible values. For example, a presence sensor which has the discrete values PRESENT and NOT_PRESENT is a discrete-valued sensor. Possible values vary among platforms but may include
normalandfailed. [-value <integer>]- Last Sensor Value-
Selects information about the sensors that have the specified sensor value.
[-discrete-value <text>]- Discrete Sensor Value-
Selects information about the discrete-valued sensors that have the specified discrete value. Possible values vary among sensors but may include
PRESENT,NOT_PRESENT,ON,OFF,OKandFAULT. [-crit-low <integer>]- Critical Low Threshold-
Selects information about the sensors that have the specified critically low threshold.
[-warn-low <integer>]- Warning Low Threshold-
Selects information about the sensors that have the specified warning-low threshold.
[-warn-hi <integer>]- Warning Hi Threshold-
Selects information about the sensors that have the specified warning-high threshold.
[-crit-hi <integer>]- Critical Hi Threshold-
Selects information about the sensors that have the specified critically high threshold.
[-inactive {true|false}]- Show Inactive Sensors-
Specify
trueto include inactive sensors in the output. By default, only sensors with the valuefalseare shown. [-hidden {true|false}]- Show Hidden Sensors-
Specify
trueto include hidden sensors in the output. By default, only sensors with the valuefalseare shown.
The following example displays information about all sensors on a cluster named cluster1:
cluster1::> system node environment sensors show
Node Sensor State Value/Units Crit-Low Warn-Low Warn-Hi Crit-Hi
mynode
Partner IO Pre
NOT_PRESENT
Partner Ctrl Pre
PRESENT
PSU2 Over Curr
OK
PSU2 Over Volt
OK
PSU2 Over Temp
OK
PSU2 Fault
OK
PSU2 DC OK
OK
PSU2 Input OK
OK
PSU2 ON
ON
PSU2 Fan2 Fault
OK
mynode
PSU2 Fan2 Speed
normal 15400 RPM 3000 3500 - 25500
PSU2 Fan1 Fault
OK
PSU2 Fan1 Speed
normal 15700 RPM 3000 3500 - 25500
PSU2 Curr
normal 28000 mA - - - -
PSU2 Temp
normal 29 C 0 5 51 61
PSU2 Present
PRESENT
PSU1 Over Curr
OK
PSU1 Over Volt
OK
PSU1 Over Temp
OK
mynode
PSU1 Fault
OK
PSU1 DC OK
OK
PSU1 Input OK
OK
PSU1 ON
ON
PSU1 Fan2 Fault
OK
PSU1 Fan2 Speed
normal 15600 RPM 3000 3500 - 25500
PSU1 Fan1 Fault
OK
PSU1 Fan1 Speed
normal 16200 RPM 3000 3500 - 25500
PSU1 Curr
normal 27000 mA - - - -
PSU1 Temp
normal 28 C 0 5 51 61
mynode
PSU1 Present
PRESENT
Battery 3.3V
normal 3400 mV 3025 3100 3500 3575
AUX 3.3V
normal 3328 mV 3024 3104 3504 3568
STBY 12V
normal 12152 mV 10478 10602 13392 13516
STBY 5V
normal 4979 mV 4602 4696 5310 5404
STBY 3.3V
normal 3375 mV 3025 3100 3500 3575
12V
normal 12152 mV 10478 10726 13268 13516
5V
normal 5003 mV 4602 4696 5310 5404
3.3V
