ONTAP commands
system node firmware bootmedia show
Display the BIOS/LOADER firmware versions stored in the boot media and running on the system
This command displays the BIOS and LOADER versions of system firmware installed on the boot media, as well as the versions currently running on the system.
{ [-fields <fieldname>,…​]
Selects the fields that you specify.
| [-instance ] }
Displays detailed information about all the controllers in the cluster.
[-node {<nodename>|local}] - Node
Selects information about the specified controller.
[-board-ID <text>] - Board Type
Selects information about the controllers with the specified board type.
[-modelName <text>] - Model Name
Selects information about the controllers with the specified model name.
[-bootmedia-bios-version <text>] - BIOS Firmware Version
Selects information about the controllers with the specified BIOS firmware version installed on the boot media.
[-bootmedia-loader-version <text>] - LOADER Firmware Version
Selects information about the controllers with the specified LOADER firmware version installed on the boot media.
[-running-bios-version <text>] - BIOS version
Selects information about the controllers with the specified BIOS firmware version currently running on the system.
[-running-loader-version <text>] - Loader version
Selects information about the controllers with the specified LOADER firmware version currently running on the system.
The following example displays the BIOS and LOADER versions installed on the bootmedia as well as the versions currently running on the system:
cluster1::> system node firmware bootmedia show
Node           Model Name     BIOS Version  LOADER Version
node01
               FAS2820
Boot Media:  19.5          8.4.0
                    Running:  19.4          8.3.0
node02
               FAS2820
                    Running:  19.4          8.3.0
