ONTAP commands
system node image package external-device delete
Delete file on external device
The delete command deletes the specified file on the external device.
-node {<nodename>|local} - Node (privilege: advanced)
The file is deleted from the external device of the node specified with this parameter. If this parameter is omitted, then the local node is used as the default node.
-package <text> - File Name (privilege: advanced)
This parameter specifies the file to be deleted.
-device {usb0|usb1} - Device (privilege: advanced)
This parameter specifies the name of the external device. Currently, only usb0 is supported.
usb0 refers to the first external USB device connected to the node (regardless of port).
::> system image package external delete -package image.tgz
