system switch ethernet create
Add information about an Ethernet switch (cluster or storage).
The system switch ethernet create command manually configures and enables the health monitoring of a specified Ethernet switch of type: cluster or storage. This command might be needed when ONTAP is unable to automatically discover and initiate monitoring of a switch through the Cisco Discovery Protocol (CDP) or the Link Layer Discovery Protocol (LLDP). If ONTAP has discovered a switch that is not in system switch ethernet show , such as if the switch was deleted using system switch ethernet delete with the force parameter, the device , address , and type parameters must match the discovered values. To identify which switches are currently monitored, use the system switch ethernet show command. If this switch was previously monitored within the past 7 days, hourly AutoSupport® log collection might automatically resume.
-device <text>- Device Name-
Name of the switch intended for monitoring. ONTAP utilizes this device name to recognize the SNMP agent it needs to interact with.
-address <IP Address>- IP Address-
IP address of the switch's management interface. This address is used as the destination of SNMP traffic and SSH connections for the purpose of monitoring and log collection, respectively.
-snmp-version {SNMPv1|SNMPv2c|SNMPv3}- SNMP Version-
SNMP version that ONTAP employs for sending SNMP requests for monitoring purposes. By default, SNMPv2c is used, as established by the Reference Configuration File (RCF) applied to the switch.
-community-or-username <text>- SNMPv2c Community String or SNMPv3 Username-
Community string used for SNMPv2 authentication, or the SNMPv3 username for SNMPv3 security. By default, the community string for SNMPv2 authentication is set to
cshm1!, as determined by the RCF that is applied to the switch. If SNMPv3 is used, the switch must be configured with the SNMPv3 username. -model {OTHER|CN1610|NX3132V|NX3232C}- Model Number-
Model of the switch. Use the OTHER option when adding a switch that requires an Ethernet switch health monitor XML configuration file, such as the BES-53248, MSN2100-CB2FC, MSN2100-CB2RC, N9K-C92300YC, and N9K-C9336C-FX2 switches. Be aware that the OTHER option selected during creation is different from the OTHER displayed by the system switch ethernet show command. In this show command, OTHER indicates that a switch is not supported for health monitoring.
-type {cluster-network|storage-network}- Switch Network-
Switch type:
cluster-networkorstorage-network. [-is-monitoring-enabled-admin {true|false}]- Enable Switch Monitoring-
Monitoring status selected by the administrator, which is set to
trueby default when not specified. During maintenance periods, a switch not manually added might be repeatedly discovered and dropped, which could potentially generate unnecessary alerts if monitoring is enabled by default. In such cases, setting this parameter tofalsedisables the monitoring process.
Example 1: Initiates Ethernet switch health monitoring for a Cisco Nexus 3132Q-V cluster switch named SwitchA.
cluster1::> system switch ethernet create -device SwitchA -address 1.2.3.4 -snmp-version SNMPv2c -community-or-username cshm1! -model NX3132V -type cluster-network
Example 2: Initiates Ethernet switch health monitoring for a NVIDIA SN2100 storage switch named SwitchB, with the SNMPv3 username snmpv3u1.
cluster1::> system switch ethernet create -device SwitchB -address 5.6.7.8 -snmp-version SNMPv3 -community-or-username snmpv3u1 -model OTHER -type storage-network
