ONTAP commands
volume file show-disk-usage
Show disk usage of file
This command requires a path to a file in a volume and displays the following information:
  • Vserver name
  • Total bytes used by the file in kilobytes
  • Full Path to the file
If not logged in as Vserver administrator, the command also requires a Vserver name.
Note The "-instance" option provides the same result as the default as there are no extra fields to display.
{ [-fields <fieldname>,…​]
| [-h ]
If this parameter is specified, the command displays total bytes used by the file in human readable form.
| [-k ]
If this parameter is specified, the command displays total bytes used by the file in kilobytes.
| [-m ]
If this parameter is specified, the command displays total bytes used by the file in megabytes.
| [-u ]
If this parameter is specified, the command displays the unique bytes used by the file (bytes that are not shared with any other file in the volume due to deduplication or FlexClone files) in kilobytes.
| [-uh ]
If this parameter is specified, the command displays the unique bytes used by the file in human readable form.
| [-uk ]
If this parameter is specified, the command displays the unique bytes used by the file in kilobytes.
| [-um ]
If this parameter is specified, the command displays the unique bytes used by the file in megabytes.
| [-instance ] }
-vserver <vserver name> - Vserver
This parameter is used to specify the Vserver that contains the file for which the command displays the total bytes used. It is required if not logged in as Vserver administrator.
-path </vol/<volume name>/<file path>> - Full Path
This required parameter is used to specify the path of the file for which the command displays the total bytes used.
[-r, -range [start offset>:<end offset]] - Block Range
If this parameter is specified, the command displays the total bytes used by the file in the specified block range.
The following example displays the disk-usage of the file file1.txt in volume /vol/root_vs0 .
cluster1::> volume file show-disk-usage -vserver vs0 -path /vol/root_vs0/file1.txt
Vserver          Total                  Path
vs0              1408KB                 /vol/root_vs0/file1.txt
cluster1::> volume file show-disk-usage -m -vserver vs0 -path /vol/root_vs0/file1.txt
Vserver          Total                  Path
vs0              1MB                    /vol/root_vs0/file1.txt
vs0::> volume file show-disk-usage -um -path /vol/root_vs0/file1.txt
Vserver       Total             Unique              Path
vs0           1MB               1MB                 /vol/root_vs0/file1.txt
