volume object-store tiering trigger
Trigger a tiering scan
The volume object-store tiering trigger command triggers a tiering and retrieve scan. Tiering and retrieval behavior is driven by the tiering and cloud retrieve policy settings on the volume. The cloud retrieve policy must be set to promote to enable scanner based retrieval.
- -vserver <vserver name>- VServer Name (privilege: advanced)
vserver name
- -volume <volume name>- Volume Name (privilege: advanced)
volume name
 PDFs
PDFs
