volume quota policy rule count show
Display count of quota rules
This command displays various counts of quota policy rules defined within a quota policy. By default, the subtotal for each volume is displayed. Optionally, the command can provide the total rule count across the entire quota policy or detailed subtotals organized by qtree and quota rule type.
[-fields <fieldname>,…] -
If you specify the
[-detail ] -
Displays rule count subtotals for each quota rule type. The subtotals for each type are computed for a specific volume and qtree.
[-hierarchy ] -
Displays rule count subtotals in hierarchical format with subtotals at the quota policy, volume, qtree, and quota rule type levels.
[-total ] -
Displays the total rule count for each Vserver and quota policy.
[-instance ]} -
Displays detailed information about all fields.
 [-vserver <vserver name>]- Vserver-
Displays quota rule counts for the specified Vserver.
 [-policy-name <text>]- Policy Name-
Displays quota rule counts for the specified quota policy.
 [-volume <volume name>]- Volume Name-
Displays quota rule counts for the specified volume.
 [-qtree <qtree name>]- Qtree Name-
Displays quota rule counts for the specified qtree.
 [-type {tree|user|group}]- Type-
Displays quota rule counts for the specified quota rule type.
 [-count-where-policy-volume-qtree-type <integer>]- Qtree/Type Subtotal-
Subtotal of rules matching the given Vserver, quota policy, volume, qtree, and quota rule type. If specified as input, only matching totals are displayed.
 [-count-where-policy-volume-qtree <integer>]- Qtree Subtotal-
Subtotal of rules matching the given Vserver, quota policy, volume, and qtree. All quota rule types are included. If specified as input, only matching totals are displayed.
 [-count-where-policy-volume-type <integer>]- Volume/Type Subtotal-
Subtotal of rules matching the given Vserver, quota policy, volume, and quota rule type. All qtrees are included. If specified as input, only matching totals are displayed.
 [-count-where-policy-volume <integer>]- Volume Subtotal-
Subtotal of rules matching the given Vserver, quota policy, and volume. All qtrees and quota rule types are included. If specified as input, only matching totals are displayed.
 [-count-where-policy-type <integer>]- Policy/Type Subtotal-
Subtotal of rules matching the given Vserver, quota policy, and quota rule type. All volumes and qtrees are included. If specified as input, only matching totals are displayed.
 [-count-where-policy <integer>]- Policy Total-
Total rule count matching the given Vserver and quota policy. All volumes, qtrees, and quota rule types are included. If specified as input, only matching totals are displayed.
The following example shows quota rule counts for Vserver vs0 , quota policy default . The total number of rules in quota policy default is 7500. There are two volumes with quota rules configured. Volume volume0 has a total of 1000 rules, and volume1 has a total of 6500 rules.
cluster1::> volume quota policy rule count show -vserver vs0 -policy-name default Vserver: vs0 Policy: default Rule Volume Count -------------------------- -------- volume0 1000 volume1 6500 2 entries were displayed.
