ONTAP commands
volume snapshot policy modify-schedule
Modify a schedule within snapshot policy
The volume snapshot policy modify-schedule command modifies the maximum number of snapshots that can be taken by a snapshot policy's schedule.
-vserver <vserver name> - Vserver Name
This specifies the Vserver on which a snapshot policy schedule is to be modified.
-policy <snapshot policy> - Snapshot Policy Name
This specifies the snapshot policy whose schedule is to be modified.
-schedule <text> - Schedule Name
This specifies the schedule that is to be modified.
[-newcount <integer>] - Maximum Snapshot Copies for Schedule
This specifies the maximum number of snapshots that can be taken by the specified schedule. The total count of all the snapshots to be retained for the policy cannot be more than 1023.
[-newsnapmirror-label <text>] - Label for SnapMirror Operations
This specifies the SnapMirror Label identified with a snapshot when it is created for the specified schedule. The SnapMirror Label is used by the Vaulting subsystem when you back up snapshots to the Vault Destination. If an empty label ("") is specified, the existing label will be deleted.
[-newretention-period <snaplock minmax period>] - SnapLock Retention Period
This specifies the retention period for snapshots created by the schedule.
The following example changes the maximum number of snapshots from five to four for a schedule named midnight on a snapshot policy named snappolicy_nightly on Vserver vs0:
cluster1::> volume snapshot policy modify-schedule -vserver vs0 -policy snappolicy_nightly -schedule midnight -newcount 4 -newretention-period "7 days"
