volume upgrade-tasks run
Triggers the M-Host upgrade tasks for the volume
The volume upgrade-tasks run command triggers the M-host upgrade tasks for the volume and sets the volume upgrade status.
-vserver <vserver name>- Vserver where the volume is located (privilege: advanced)-
This specifies the vserver on which the volume is located.
-volume <volume name>- Volume on which we are running triggering the upgrade (privilege: advanced)-
This specifies the volume on which we have to trigger the upgrade-tasks.
The following example triggers upgrade-tasks on volume named vol1 on a vserver named vs0:
node::> volume upgrade-tasks run -vserver vs1 -volume vol1
