ONTAP commands
vserver cifs domain trusts show
Display discovered trusted domain information
The vserver cifs domain trusts show command displays information about the trusted domains for the CIFS home domain of one or more Vservers. The displayed trusted domain information is grouped by node and Vserver, and each group is preceded by the node and Vserver identification. This command is not supported for workgroup CIFS servers.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node
If you use this parameter, the command displays information only about trusted domains of the home domains for the specified node.
[-vserver <vserver name>] - Vserver
If you use this parameter, the command displays information only about trusted domains of the home domain for the specified Vserver.
[-home-domain <domain name>] - Home Domain Name
If you use this parameter, the command displays information only about trusted domains of the home domain with the specified name.
[-trusted-domain <domain name>,…​] - Trusted Domain Name
If you use this parameter, the command displays information only about trusted domains with the specified name.
The following example displays information about all the bidirectional trusted domains for node-01 and vserver_1.
cluster1::> vserver cifs domain trusts show -node node-01 -vserver vserver_1
Node: node-01
Vserver: vserver_1
Home Domain            Trusted Domain
EXAMPLE.COM            CIFS1.EXAMPLE.COM,
                       CIFS2.EXAMPLE.COM
