vserver cifs superuser show
Display superuser permissions for CIFS accounts
The vserver cifs superuser show command displays all account names with superuser privileges. The command output depends on the parameter or parameters specified with the command. If you do not specify any parameters, the command displays the following superuser information for all CIFS servers:
Vserver name
CIFS server NetBIOS name
Domain
Account Name
[-fields <fieldname>,…]-
If you specify the
[-instance ](privilege: advanced) } -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver name>]- Vserver (privilege: advanced)-
If you specify this parameter, the command displays superuser information of only the specified Vservers.
 [-domain <CIFS domain>]- Domain (privilege: advanced)-
If you specify this parameter, the command displays superuser information of only for accounts that are in the specified domain.
 [-accountname <CIFS account>]- User (privilege: advanced)-
If you specify this parameter, the command displays superuser information of only the CIFS servers with the specified superuser account.
 [-cifs-server <NetBIOS>]- CIFS Server NetBIOS Name (privilege: advanced)-
If you specify this parameter, the command displays superuser information of only the Vservers with specified CIFS server name.
The following example displays superuser information of all Vservers.
vs1::> vserver cifs superuser show Vserver CIFS Server Domain Account Name -------------- --------------- --------------- ------------ vs1 SMB_SERVER1 CIFSDOMAIN ADMINISTRATOR vs2 SMB_SERVER2 CIFSDOMAIN ADMINISTRATOR
