ONTAP commands
vserver config-replication resume
Resume Vserver configuration replication
This command resumes configuration replication of the Vserver which was temporarily paused by using the vserver config-replication pause command. Successful completion of the command ensures that configuration replication has been resumed for the Vserver.
-vserver <vserver name> - Vserver name (privilege: advanced)
== Examples
cluster::> vserver config-replication resume -vserver vs1
