ONTAP commands
vserver consistency-group attach
Attach a consistency group to an existing parent consistency group
The vserver consistency-group attach command can be used to attach a consistency group to a parent consistency group.
-vserver <Vserver Name> - Vserver Name
This parameter specifies the Vserver that contains the consistency group that is to be attached.
-consistency-group <text> - Consistency Group
This parameter specifies the consistency group that is to be attached.
-parent-consistency-group <text> - Parent Consistency Group
This parameter specifies the parent consistency group to be attached to.
[-new-name <text>] - New Name for the Consistency Group
This parameter optionally specifies a new name for the attached consistency group.
The following command attaches the consistency group singleCG to a parent consistency group parentCG in Vserver vs0.
cluster1::> vserver consistency-group attach -vserver vs0 -consistency-group childCG -parent-consistency-group parentCG
    [Job 174] Job succeeded: Success
The following command attaches the consistency group singleCG to a parent consistency group parentCG in Vserver vs0, which is renamed to childCG.
cluster1::> vserver consistency-group attach -vserver vs0 -consistency-group childCG -parent-consistency-group parentCG -new-name childCG
        (vserver consistency-group attach)
