ONTAP commands
vserver consistency-group lun show
Display a list of existing consistency group Luns
The command displays information for consistency group LUNs. Use the ` instance ` parameter to display additional consistency group LUN details.
{ [-fields <fieldname>,…​]
This specifies the fields that need to be displayed.
| [-instance ] }
[-vserver <Vserver Name>] - Vserver Name
Selects information about the consistency group LUNs in the specified Vserver.
[-consistency-group <text>] - Consistency Group
Selects information about the consistency group LUNs in the specified consistency group.
[-parent-consistency-group <text>] - Parent Consistency Group
Selects information about the consistency group LUNs in the specified parent consistency group.
{ [-path <path>] - LUN Path
Selects information about the consistency group LUN that matches the specified LUN path.
| [-lun <text>] - LUN Name
Selects information about the consistency group LUN that matches the specified LUN name.
[-volume <volume name>] - Volume Name
Selects information about the consistency group LUNs that matches the specified volume name.
[-qtree <qtree name>] - Qtree Name }
Selects information about the consistency group LUNs that matches the specified qtree name.
[-uuid <UUID>] - LUN UUID
Selects information about the consistency group LUN that matches the specified LUN UUID.
[-vserver-uuid <UUID>] - Vserver UUID
Selects information about the consistency group LUNs that matches the specified Vserver UUID.
[-consistency-group-uuid <UUID>] - Consistency Group UUID
Selects information about the consistency group LUNs that matches the specified consistency group UUID.
[-parent-consistency-group-uuid <UUID>] - Parent Consistency Group UUID
Selects information about the consistency group LUNs that matches the specified parent consistency group UUID.
The following command lists all the LUNS that are associated with a consistency group.
cluster1::> consistency-group lun show
  (vserver consistency-group lun show)
                         Parent
           Consistency   Consistency   LUN
Vserver    Group         Group         Path
vs0        ChildCG_1     ParentCG      /vol/ParentCG_01_vol_1/ChildCG_1_lun_1_1
vs0        ChildCG_2     ParentCG      /vol/ParentCG_02_vol_1/ChildCG_2_lun_1_1
vs0        singleCG      -             /vol/singleCG_vol_1/singleCG_lun_1_1
vs0        singleCG      -             /vol/singleCG_vol_1/singleCG_lun_1_2
vs1        singleCG      -             /vol/singleCG_vol_1/singleCG_lun_1_1
vs1        singleCG      -             /vol/singleCG_vol_1/singleCG_lun_1_2
6 entries were displayed.
