vserver consistency-group snapshot create
Create a new consistency group Snapshot copy
The vserver consistency-group snapshot create command creates a snapshot of a specified consistency group.
-vserver <Vserver Name>- Vserver Name-
This parameter specifies the Vserver that contains the consistency group where the snapshot is to be created.
-consistency-group <text>- Consistency Group Name-
This parameter specifies the consistency group where a snapshot is to be created.
[-parent-consistency-group <text>]- Parent Consistency Group Name-
This parameter specifies the parent consistency group where a snapshot is to be created.
-snapshot <snapshot name>- Snapshot Copy Name-
This parameter specifies the name of the snapshot that is to be created.
[-consistency-type {crash|application}]- Consistency Type-
This parameter specifies the consistency level of a snapshot to be created. The default value is
crash. [-comment <text>]- Comment-
This parameter specifies the comment associated with a snapshot to be created.
[-snapmirror-label <text>]- Snapmirror Label-
This parameter specifies the label associated with a snapshot to be created.
[-write-fence {true|false}]- Take write fence-
This parameter specifies if a write fence is taken on the volumes in the consistency group while creating a snapshot.
The following example creates a snapshot named snap1 on a child consistency group named cg1 in parent consistency group parentCg on a Vserver named vs0. The snapshot has a comment "Feb golden image", a SnapMirror label "Label" and is crash-consistent.
cluster1::> vserver consistency-group snapshot create -vserver vs0 -consistency-group cg1 -parent-consistency-group parentCg -snapshot snap1 -comment "Feb golden image" -snapmirror-label "Label" -consistency-type crash
(vserver consistency-group snapshot create)
[Job 100] Job succeeded: Success
