ONTAP commands
vserver consistency-group volume show
Display a list of existing consistency group Volumes
The command displays information for consistency group volumes. Use the ` instance ` parameter to display additional consistency group volume details.
{ [-fields <fieldname>,…​]
This specifies the fields that need to be displayed.
| [-instance ] }
[-vserver <Vserver Name>] - Vserver Name
Selects information about the consistency group volumes in the specified Vserver.
[-consistency-group <text>] - Consistency Group
Selects information about the consistency group volumes in the specified consistency group.
[-parent-consistency-group <text>] - Parent Consistency Group
Selects information about the consistency group volumes in the specified parent consistency group.
[-volume <volume name>] - Volume
Selects information about the specified consistency group volume.
[-uuid <UUID>] - Volume UUID
Selects information about the consistency group volume that matches the specified volume UUID.
[-vserver-uuid <UUID>] - Vserver UUID
Selects information about the consistency group volumes that matches the specified Vserver UUID.
[-consistency-group-uuid <UUID>] - UUID
Selects information about the consistency group volumes that matches the specified consistency group UUID.
[-parent-consistency-group-uuid <UUID>] - Parent CG UUID
Selects information about the consistency group volumes that matches the specified parent consistency group UUID.
[-size {<integer>[KB|MB|GB|TB|PB]}] - Size
Selects information about the consistency group volumes that have the specified size.
[-space-available {<integer>[KB|MB|GB|TB|PB]}] - Available Space
Selects information about the consistency group volumes that have the specified available space.
[-space-used {<integer>[KB|MB|GB|TB|PB]}] - Used Space
Selects information about the consistency group volumes that have the specified used space.
[-export-policy <export policy name>] - Volume Export Policy
Selects information about the consistency group volumes that have the specified export policy.
[-cifs-shares <Share>,…​] - Volume CIFS Share Names
Selects information about the consistency group volumes that have the specified CIFS share name.
The following command lists all the volumes that are associated with a consistency group.
cluster1::> vserver consistency-group volume show
          (vserver consistency-group volume show)
                         Parent
           Consistency   Consistency                         Available  Used
Vserver    Group         Group         Volume        Size    Space      Space
san_vs0    Child_CG_1    Parent_cg     vol_child1_1  206MB   205.7MB    296KB
san_vs0    Child_CG_2    Parent_cg     vol_child2_1  206MB   205.7MB    280KB
san_vs0    Child_CG_3    Parent_cg     vol_child3_1  206MB   205.7MB    260KB
san_vs0    Child_CG_3    Parent_cg     vol_child3_2  206MB   205.7MB    332KB
san_vs0    Child_CG_3    Parent_cg     vol_child3_3  206MB   205.7MB    296KB
5 entries were displayed.
