vserver nfs credentials show
Show credentials cached by NFS
The vserver nfs credentials show command displays the user account credentials stored on a specific node for a given UNIX user. This command has no effect if the vserver specified has no active data interfaces on the node where the command is run.
[-fields <fieldname>,…]-
If you specify the
[-instance ](privilege: advanced) } -
If you specify the
-instanceparameter, the command displays detailed information about all fields. -node <nodename>- Node (privilege: advanced)-
The name of the node on which the command is executed.
-vserver <vserver name>- Vserver (privilege: advanced)-
Use this parameter to search for user credentials in the Vserver you specify.
-unix-user-id <integer>- UNIX User ID (privilege: advanced) -
Use this parameter to search for user credentials for the UNIX user id you specify.
[-client-ip <IP Address>]- Client IP Address (privilege: advanced)-
Use this parameter to search for user credentials for the client ip you specify.
-unix-user-name <text>- UNIX User Name (privilege: advanced) -
Use this parameter to search for user credentials for the UNIX user name you specify.
-unix-group-id <integer>- UNIX Group ID (privilege: advanced) -
Use this parameter to search for user credentials for the UNIX group id you specify.
-unix-group-name <text>- UNIX Group Name (privilege: advanced) } -
Use this parameter to search for user credentials for the UNIX group name you specify.
[-flags {ip-qualifier-configured|ip-qualifier-not-configured|unix-extended-creds-present|no-unix-extended-creds|unix-extended-creds-requested|unix-creds-transient-failure|cifs-creds-present|no-cifs-creds|cifs-creds-requested|cifs-cifs-transient-failure|place-holder|transient-failure|transient-error-on-last-refresh|id-name-mapping-present|no-id-name-mapping|id-name-mapping-requested|id-name-mapping-transient-failure|unix-cred-is-partial}]- Credential Entry Flags (privilege: advanced)-
The credential entry flags.
[-last-refresh-time <[<integer>h][<integer>m][<integer>s]>]- Time since Last Refresh (privilege: advanced)-
Time since last refreshed.
[-last-access-time <[<integer>h][<integer>m][<integer>s]>]- Time since Last Access (privilege: advanced)-
Time since last access.
[-hit-count <integer>]- Number of Hits (privilege: advanced)-
Number of times the cached credential is fetched successfully.
[-unix-cred-flags <integer>]- UNIX Credential Flags (privilege: advanced)-
UNIX credentials flags.
[-unix-cred-domain-id <integer>]- UNIX Credential Domain ID (privilege: advanced)-
UNIX credentials domain ID.
[-unix-cred-uid <integer>]- UNIX Credential UID (privilege: advanced)-
User ID of the UNIX user.
[-unix-cred-primary-gid <integer>]- UNIX Credential Primay GID (privilege: advanced)-
Primary GID of the UNIX user.
[-unix-cred-additional-gids <integer>,…]- UNIX Credential Additional GIDs (privilege: advanced)-
Additional GIDs of the UNIX user.
[-win-cred-flags <integer>]- Windows Credential Flags (privilege: advanced)-
Windows credentials flags.
[-win-cred-user-sid <text>]- Windows Credential User SID (privilege: advanced)-
SID of the windows user.
[-win-cred-primary-group-sid <text>]- Windows Credential Primary Group SID (privilege: advanced)-
SID of the windows user's primary group.
[-win-cred-domain-sids <text>,…]- Windows Credential Domain SIDs (privilege: advanced)-
Domain SIDs of the windows user.
Show the credentials cached by NFS Cred Store for the UNIX user node1 on node node1.
gnk1cluster1::*> vserver nfs credentials show -node gnk1cluster1-01 -vserver coke -unix-user-name root
Credentials
Node: gnk1cluster1-01
Vserver: coke
Client IP: -
Flags: ip-qualifier-not-configured, unix-extended-creds-present, cifs-creds-present, id-name-mapping-present
Time since Last Refresh: 10s
Time since Last Access: 5s
Hit Count: 24
Unix Credentials:
Flags: 0
Domain ID: 0
UID: 0
Primary GID: 1
Additional GIDs: 1
Windows Credentials:
Flags: 8759
User SID: S-1-5-21-2552784647-1202982559-4146209732-500
Primary Group SID: S-1-5-21-2552784647-1202982559-4146209732-513
Domain SIDs: S-1-5-21-2552784647-1202982559-4146209732
S-1-1
S-1-5
S-1-5-32
ID-Name Information:
Type: user
