ONTAP commands
vserver nfs storepool config modify
Modify the storepool configuration
The vserver nfs storepool config modify command modifies NFSv4.x storepool configuration parameters:
[-limit-enforce {enabled|disabled}] - Storepool Limit Enforce Control (privilege: advanced)
This parameter is used to enable or disable the limit enforcement. The default value is disabled .
[-blocked-client-ttl <integer>] - Blocked Client TTL in Seconds (privilege: advanced)
This parameter is used to set the blocked client eviction time-to-live (TTL). The client will be able to reconnect with NFs4.x server after this value expires. Valid values are from 0 to 604800 seconds (7 days). The default value is 86400 .
The following is an example of how to modify the storepool limit-enforce parameter.
cluster1::*> vserver nfs storepool config modify -limit-enforce disabled -blocked-client-ttl 90000
