vserver nvme namespace delete
Delete an NVMe namespace
The vserver nvme namespace delete command deletes an NVMe namespace from a specified Vserver and volume.
-vserver <Vserver Name>- Vserver Name-
Specifies the Vserver.
-path <path>- Namespace Path-
Specifies the path of the NVMe namespace. Examples of correct NVMe namespace paths:
/vol/vol1/ns1and/vol/vol1/qtree1/ns1 [-skip-mapped-check <true>]- Skip Mapped Check-
This option is required to delete an NVMe namespace that is attached to a subsystem.
[-foreground {true|false}]- Foreground-
This parameter specifies whether the operation runs in the foreground. The default setting is true (the operation runs in the foreground). When set to true, the command will not return until the operation completes.
cluster1::> vserver nvme namespace delete -vserver vs1 -path /vol/nsvol/ns1
Deletes the NVMe namespace at path /vol/nsvol/ns1 on Vserver vs1 .
