ONTAP commands
vserver peer delete
Delete a Vserver peer relationship
The vserver peer delete command deletes the Vserver peer relationship between two Vservers.
-vserver <vserver> - Vserver Name
Specifies the local Vserver name for which you want to delete the Vserver peer relationship.
-peer-vserver <vserver> - Peer Vserver Name
Specifies the peer Vserver name with which the Vserver peer relationship was established.
[-force <true>] - Force Delete
Deletes the Vserver peer relationship even if the remote cluster is not accessible due to, for example, network connectivity issues.
[-foreground {true|false}] - Foreground
This parameter optionally specifies whether the Vserver peer delete operation can be executed in the background. If nothing is specified, by default the Vserver peer delete operation is executed in the background.
The following example illustrates how to delete the Vserver peer relationship between two Vservers lvs1.example.com residing on cluster1 , and pvs1.example.com residing on cluster2 .
cluster1::> vserver peer delete -vserver lvs1.example.com -peer-vserver pvs1.example.com
