vserver services web show
Display the current configuration of web services
This command displays the availability of the web services on Vservers. Only the services that are installed on every node in the cluster can be configured on Vservers whose type is not 'node'. Enabled services must include authorization configuration in the vserver services web access command for the services to be externally available.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]- Vserver-
Identifies a Vserver for hosting a specific web service.
[-name <text>]- Service Name-
Identifies the name of the web service.
[-type <vserver type>]- Type of Vserver-
Identifies the type of Vserver on which the service is hosted.
[-version <text>]- Version of Web Service-
Defines the version number of the service in the format of major.minor.patch.
[-description <text>]- Description of Web Service-
Provides a short description of the web service.
[-long-description <text>]- Long Description of Web Service-
Provides a long description of the web service.
[-requires <requirement>,…]- Service Requirements-
Defines the list of requirements that must be met for the service to be successfully executed. Requirements are defined as a service name, a comparison operator (<⇒), and a version number.
[-default-roles <text>,…]- Default Authorized Roles-
Defines the roles that are automatically granted access to the service in the vserver services web access show configuration.
[-enabled {true|false}]- Enabled-
Defines the availability of a service on the Vserver. Disabled services are not accessible through the Vserver's network interfaces. This parameter's default value is dependent on the service. In general, services that provide commonly used features are enabled by default.
[-ssl-only {true|false}]- SSL Only-
Defines the encryption enforcement policy for a service on the Vserver. Services for which this parameter is set to true support SSL only and cannot be used over unencrypted HTTP. The default for this value is 'false'.
This example displays the availability of the web services on the Vservers.
cluster1::vserver services web> show
Vserver Type Service Name Description Enabled
cluster1 admin cem OBSOLETE true
cluster1 admin ontapi Remote Administrative API true
cluster1 admin portal Data ONTAP Web Services true
Portal
n6070-8 node cem OBSOLETE true
n6070-8 node ontapi Remote Administrative API true
n6070-8 node portal Data ONTAP Web Services true
Portal
n6070-8 node spi Service Processor false
Infrastructure
n6070-8 node supdiag Support Diagnostics true
Support
n6070-9 node cem OBSOLETE true
n6070-9 node ontapi Remote Administrative API true
n6070-9 node portal Data ONTAP Web Services true
Portal
n6070-9 node spi Service Processor false
Infrastructure
n6070-9 node supdiag Support Diagnostics false
Support
13 entries were displayed.
