vserver show-aggregates
Show details of aggregates in a Vserver
The vserver show-aggregates command displays the details of all the aggregates that are associated with Vservers. The aggregate details displayed are the aggregate name, state, available size, the type of aggregate and the SnapLock type.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-vserver <vserver>]- Vserver
If this optional parameter is specified, the command displays the details of aggregates that are associated with the specified Vserver.
- [-aggregate <aggregate name>]- Aggregate
If this optional parameter is specified, the command displays all of the Vservers configured with the specified aggregate.
The following example displays the aggregates configured for Vserver vs.
cluster1::> vserver show-aggregates -vserver vs
                                       Available
Vserver        Aggregate      State         Size Type    SnapLock-Type
vs             aggr1          online     795.2MB hdd     non-snaplock
vs             aggr2          online     795.2MB hdd     non-snaplock
2 entries were displayed.
 PDFs
PDFs
