vserver vscan scanner-pool resolve-hostnames
Resolve the hostnames configured in the scanner pool
The vserver vscan scanner-pool resolve-hostnames command resolves the host names configured in the scanner pool and update it with the IP addresses. This command also updates the active scanner pool configuration of the Vserver if the scanner pool is part of that. You must run this command for the scanner pool whose host name entry is modified in the DNS server.
-vserver <vserver>- Vserver-
This parameter specifies the name of the Vserver for which you want to resolve host names.
-scanner-pool <Scanner pool>- Scanner Pool-
This parameter specifies the name of the scanner pool for which you want to resolve host names.
The following example resolves the host names of a scanner pool:
cluster1::> vserver vscan scanner-pool resolve-hostnames -vserver vs1 -scanner-pool SP
Cluster1::> vserver vscan scanner-pool show -vserver vs1 -scanner-pool SP
Vserver: vs1
Scanner Pool: SP
Applied Policy: primary
Current Status: on
Cluster on Which Policy Is Applied: Cluster1
Scanner Pool Config Owner: vserver
List of IPs of Allowed Vscan Servers: 10.72.204.27, 10.72.204.29
List of Host Names of Allowed Vscan Servers: vmwin204-27.fsct.nb, vmwin204-29.fsct.nb
List of Privileged Users: cifs\u1, cifs\u2
