vserver vscan scanner-pool show
Display scanner pools
The vserver vscan scanner-pool show command displays information about the Vscan scanner pools belonging to the Vserver. It also displays the scanner policy applied to the scanner pool and its current status in Vserver scope. If you do not specify any parameters, the command displays the following information about all scanner pools:
Vserver name
Scanner pool
Scanner pool owner
Scanner policy
Current status
Cluster on which policy is applied
List of servers
List of host names
List of privileged user
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver name>]- Vserver-
If you specify this parameter, the command displays information only about the scanner pools for the specified Vserver.
 [-scanner-pool <Scanner pool>]- Scanner Pool-
If you specify this parameter, the command displays information only about the specified scanner pool.
 [-scanner-policy <Scanner policy>]- Applied Policy-
If you specify this parameter, the command displays information only about the scanner pools for the specified scanner policy.
 [-current-status {on|off}]- Current Status-
If you specify this parameter, the command displays information only about the scanner pools that have the specified status.
 [-cluster <Cluster name>]- Cluster on Which Policy Is Applied-
If you specify this parameter, the command displays information only about the scanner pools that are applied to the specified cluster.
 [-owner <Configuration owner>]- Scanner Pool Config Owner-
If you specify this parameter, the command displays information only about the scanner pools that have the specified owner.
 [-servers <IP Address>,…]- List of IPs of Allowed Vscan Servers-
If you specify this parameter, the command displays information only about the scanner pools that have the specified IP address or IP addresses.
 [-hostnames <text>,…]- List of Host Names of Allowed Vscan Servers-
If you specify this parameter, the command displays information only about the scanner pools that have the specified host name or host names.
 [-privileged-users <Privileged user>,…]- List of Privileged Users-
If you specify this parameter, the command displays information only about the scanner pools that have the specified privileged user or users.
 [-request-timeout <[<integer>d][<integer>h][<integer>m][<integer>s]>]- Request Service Timeout (privilege: advanced)-
If you specify this parameter, the command displays information only about the scanner pools that have the specified request-timeout.
 [-scan-queue-timeout <[<integer>d][<integer>h][<integer>m][<integer>s]>]- Scan Queue Timeout (privilege: advanced)-
If you specify this parameter, the command displays information only about the scanner pools that have the specified scan-queue-timeout.
 [-session-setup-timeout <[<integer>d][<integer>h][<integer>m][<integer>s]>]- Session Setup Timeout (privilege: advanced)-
If you specify this parameter, the command displays information only about the scanner pools that have the specified session-setup-timeout.
 [-session-teardown-timeout <[<integer>d][<integer>h][<integer>m][<integer>s]>]- Session Teardown Timeout (privilege: advanced)-
If you specify this parameter, the command displays information only about the scanner pools that have the specified session-teardown-timeout.
 [-max-session-setup-retries <integer>]- Max Number of Consecutive Session Setup Attempts (privilege: advanced)-
If you specify this parameter, the command displays information only about the scanner pools that have the specified max-session-setup-retries.
The following example displays information about all scanner pools.
Cluster1::> vserver vscan scanner-pool show
            Scanner    Pool                         Privileged      Scanner
Vserver     Pool       Owner   Servers              Users           Policy
vs1         SP         vserver 1.1.1.1,             cifs\u1,        primary
                               10.72.204.27         cifs\u2
vs1         p1         vserver 3.3.3.3              cifs\u1,        secondary
                                                    cifs\u2
2 entries were displayed.
The following example displays detailed information about one scanner pool.
Cluster1::> vserver vscan scanner-pool show -vserver vs1 -scanner-pool SP
Vserver: vs1
                               Scanner Pool: SP
                             Applied Policy: primary
                             Current Status: on
         Cluster on Which Policy Is Applied: Cluster1
                  Scanner Pool Config Owner: vserver
       List of IPs of Allowed Vscan Servers: 1.1.1.1, 10.72.204.27
List of Host Names of Allowed Vscan Servers: 1.1.1.1, vmwin204-27.fsct.nb
                   List of Privileged Users: cifs\u1, cifs\u2
