Command reference
event filter rule delete
Delete a rule for an event filter
The event filter rule delete command deletes a rule from an event filter. The position of all the rules following the deleted rule is updated to maintain a contiguous sequence. Use event filter show command to view the filters and the rules associated with them.
-filter-name <text> - Filter Name
Use this mandatory parameter to specify the name of the event filter from which you want to delete the rule. Rules cannot be deleted from system-defined filters.
-position <integer> - Rule Position
Use this mandatory parameter to specify the position of the rule to delete from the filter. It should be in the range (1..n-1), where 'n' is the position of the last rule, which is an implicit rule.
The following example deletes a rule at position 2 from an existing event filter "emer-and-wafl":
cluster1::> event filter show
Filter      Rule Rule                                    SNMP Trap
Name        Posn Type     Message Name     Severity      Type      Parameters
default-trap-events
            1    include  *                EMERGENCY, ALERT
            2    include  *                *             Standard, Built-in
            3    exclude  *                *             *         *=*
emer-and-wafl
            1    include  wafl.scan.*      ALERT         *         *=*
            2    include  wafl.*           EMERGENCY     *         *=*
            3    include  *                *             Standard  *=*
            4    exclude  *                *             *         *=*
important-events
            2    include  callhome.*       ERROR         *         *=*
            3    exclude  *                *             *         *=*
no-info-debug-events
            1    include  *                EMERGENCY, ALERT, ERROR, NOTICE
            2    exclude  *                *             *         *=*
12 entries were displayed.
cluster1::> event filter rule delete -filter-name emer-and-wafl -position 2
default-trap-events
            3    exclude  *                *             *         *=*
emer-and-wafl
            2    include  *                *             Standard  *=*
            3    exclude  *                *             *         *=*
important-events
            3    exclude  *                *             *         *=*
            2    exclude  *                *             *         *=*
11 entries were displayed.
