security key-manager keystore disable
Disable an active key manager
This command disables the keystore represented by the supplied Vserver, keystore-type, and config-name combination.
-vserver <Vserver Name>- Vserver (privilege: advanced)-
Use this parameter to specify the Vserver of the desired configuration.
The following example disables a configuration named sampleConfig for Barbican on Vserver vsTest.
cluster-1::> security key-manager keystore disable -vserver vsTest -keystore-type BARBICAN -config-name sampleConfig
