Command reference
security key-manager keystore enable
Enable or switch to an inactive keystore configuration
This command enables the keystore represented by the supplied Vserver, keystore-type, and config-name combination. If the specified Vserver already has a keystore enabled, then the enabled configuration is switched to the desired keystore configuration and the previous configuration is left in an inactive/disabled state.
-vserver <vserver name> - Vserver Name
Use this parameter to specify the Vserver of the desired configuration.
-keystore-type <Key Store Type> - Keystore Type
Use this parameter to specify the keystore type of the desired configuration.
-config-name <text> - Configuration Name
Use this parameter to specify the configuration name of the desired configuration.
The following example enables a configuration named sampleConfig for the configured AKV on Vserver vsTest.
cluster-1::> security key-manager keystore enable -vserver vsTest -keystore-type AKV -config-name sampleConfig
The following example switches the configuration on Vserver vsTest to a new keystore configuration named newConfig.
cluster-1::> security key-manager keystore enable -vserver vsTest -keystore-type AKV -config-name newConfig
