Command reference
security login duo delete
Delete a Duo Configuration
The security login duo delete command deletes the Duo configuration.
-vserver <vserver name> - Vserver
This parameter optionally specifies the Vserver name of the Duo configurations.
The following command deletes the Duo configurations of the Vserver vs1.
cluster1::> security login duo delete -vserver vs1
