Command reference
security oauth2 scope scope-to-cli generate
Generate CLI REST role command for the given OAuth 2.0 scope
The security oauth2 scope scope-to-cli generate command generates on ONTAP CLI security login rest-role create command that is the equivalent of the specified OAuth 2.0 scope string.
-scopeString <text> - OAuth 2.0 scope
The OAuth 2.0 scope string. This parameter is required.
To generate ONTAP CLI command given an OAuth 2.0 scope string applicable to all clusters for an ONTAP role named restclusterrole for the REST API URI /api/cluster with readonly access:
cluster1::gt; security oauth2 scope scope-to-cli generate -scopeString ontap:*:restclusterrole:readonly:*:/api/cluster
Command for cluster <All>:
security login rest-role create -role restclusterrole -access readonly -api /api/cluster
