Command reference
snaplock legal-hold abort
Abort Snaplock legal-hold operation.
The snaplock legal-hold abort is used to abort an ongoing legal-hold operation. The type of legal-hold operations that can be aborted using this command are begin, end and dump-files. This command only aborts operations that have not yet completed. Only a user with security login role vsadmin-snaplock is allowed to perform this operation.
-vserver <vserver name> - Vserver Name
Specifies the vserver on which the legal-hold operation is running.
-operation-id <integer> - Operation ID
Specifies the operation ID of the legal-hold operation to be aborted.
The following example aborts an ongoing legal-hold operation with operation-id 16842754 :
vs1::> snaplock legal-hold abort -operation-id 16842754
            vs1::>
