Command reference
snapmirror mediator modify
Modify mediator configuration
The snapmirror mediator modify command is used to modify a mediator configuration entry.
-peer-cluster <text> - Peer cluster
Peer cluster for which the mediator is configured.
[-mediator-address <IP Address>] - Mediator Ip Address
Specifies the IP address of the mediator. This is only applicable for ONTAP Mediator.
[-type {on-prem|cloud}] - Mediator Type
Specifies the type of the mediator. The value on-prem represents ONTAP Mediator. The value cloud represents ONTAP cloud mediator.
[-use-http-proxy-local {true|false}] - Use HTTP Proxy on Local Cluster
Specifies if the local cluster should use http-proxy server while making REST API calls to mediator. This option is only supported for ONTAP cloud mediator.
[-use-http-proxy-remote {true|false}] - Use HTTP Proxy on Remote Cluster
Specifies if the remote cluster should use http-proxy server while making REST API calls to mediator. This option is only supported for ONTAP cloud mediator.
The following example modifies a mediator configuration entry.
clusA::> snapmirror mediator modify -peer-cluster clusB -type cloud -use-http-proxy-local true -use-http-proxy-remote true -strict-cert-validation true
