Command reference
storage aggregate flexaggr show
Display the list of aggregates and their defunct state
The storage aggregate flexaggr show command displays information about FlexAggrs. The command output depends on the parameter or parameters specified with the command. If no parameters are specified, the command displays the following information about all aggregates:
  • Aggregate name
  • State
  • Nodes
  • Is Root Aggregate
  • Flexible Aggregate ID
  • Flexible Aggregate State
  • Is Home Node Unavailable
  • Is Defunct
To display detailed information about a single aggregate, use the -aggregate parameter.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-aggregate <aggregate name>] - Aggregate
If this parameter is specified, the command displays information only about the aggregate that has the specified name.
[-flexaggr-id <integer>] - FlexAggr ID
If this parameter is specified, the command displays information only about the aggregates that have the specified Flexible Aggregate ID.
[-state <aggregate state>] - State
If this parameter is specified, the command displays information only about the aggregates that have the specified state.
[-nodes {<nodename>|local}] - Node
If this parameter is specified, the command displays information only about the aggregates from the specified node.
The following example displays information about all Flexible Aggregates:
cluster1::> aggr flexaggr show
Aggregate           State   Node         Root  FA Id  FA State   HomeUn Dfnct
dataFA_2_p0_i1      online  node-vsim1   false      2 completed  false  false
dataFA_4_p0_i1      online  node-vsim1   false      4 completed  false  true
rootFA_1_p0_i1      online  node-vsim1   true       1 completed  -      false
rootFA_3_p0_i1      online  node-vsim1   true       3 completed  false  true
4 entries were displayed.
