Command reference
storage firmware shelf rename
Rename a shelf firmware file
The storage firmware shelf rename command renames the specified shelf firmware file on each node.
-oldname <text> - Old Filename (privilege: advanced)
This parameter specifies the firmware file to rename.
-newname <text> - New Filename (privilege: advanced)
This parameter specifies the new name of the firmware file.
The following example renames the shelf firmware file with the name IOM12.0210.SFW to IOM12.000.SFW on each node:
cluster1::*> storage firmware shelf rename -oldname IOM12.0210.SFW -newname IOM12.000.SFW
