Command reference
storage port disable
Disable a storage port
The storage port disable command disables a specified storage port.
-node {<nodename>|local} - Node
Use this parameter to specify the node on which the port resides.
-port <text> - Port
Use this parameter to specify the port that needs to be disabled.
[-force <true>] - Force (privilege: advanced)
Use this optional parameter to force the disabling of the storage port. The parameter can be used to disable the specified port even if some devices can only be accessed using this port. Note that doing so might cause multiple device failures.
The following example disables port 0a on node node1:
cluster1::> storage port disable -node node1 -port 0a
