Command reference
system bridge options show
Show state of configurable options for all bridges
The system bridge options show command displays the value of configurable options which apply to all ATTO FibreBridges in the cluster configuration. If the user specifies the command without parameters, the output displays the current value of all the configurable options supported by the cluster.
[-fields <fieldname>,…​]
| [-instance ] (privilege: advanced) }
[-option-name <text>] - Option Name (privilege: advanced)
The options supported are:
  • enable.automatic.addition
    Allowable values {true, false}.
    This option controls whether or not bridges are automatically added for in-band monitoring by the Fabric Health Monitor.
    If set to true, the feature is enabled and all ATTO 7500N and 7600N bridges will automatically be added for in-band monitoring by the Fabric Health Monitor.
    If set to false, the feature is disabled and ATTO FibreBridges will not be automatically added for monitoring. They can be left unmonitored, or manually added for SNMP monitoring.
Note that this command is cluster-specific. To determine the option setting on both clusters of a MetroCluster system, the command must be executed once on each cluster of the MetroCluster system.
[-option-value <text>] - Option Value (privilege: advanced)
The option-value parameter specifies the value of the option. Allowable values are described for each option supported in the list above.
The following example displays the current setting of the bridge options:
siteA::*> system bridge options show
  Option Name                 Option Value      Option Hint
  enable.automatic.addition   true              {true,false} - enable auto-add
siteA::*>
