Command reference
system services ndmp password
(DEPRECATED)-Change the NDMP password for the node
Note This node-scoped NDMP command is deprecated. Node-scoped NDMP functionality may be removed in a future release of ONTAP. Use the Vserver-aware "vserver services ndmp generate-password " command.
The system services ndmp password command is used to change the NDMP password for a node in the cluster.
-node {<nodename>|local} - Node
The specific node for which the password is to be changed.
The following example is used to change the NDMP password for the node named node1:
cluster1::> system services ndmp password -node node1
Please enter password:
Confirm password:
