Command reference
system switch ethernet polling-interval modify
Modify the polling interval for Ethernet switch health
The system switch ethernet polling-interval modify command modifies the interval in which the Ethernet switch health monitor polls cluster, management and storage switches.
[-polling-interval <integer>] - Polling Interval
Specifies the interval in which the health monitor polls switches. The interval is in minutes. The default value is 5. The allowed range of values is 2 to 120.
cluster1::> system switch ethernet polling-interval modify -polling-interval 41
Modifies the polling interval of the switches.
