volume analytics cluster-config reset
Reset the file system analytics cluster configuration
The volume analytics cluster-config reset command resets the cluster-level file system analytics configuration to the platform default.
The following example resets the cluster level file system analytics configuration:
cluster::*> volume analytics cluster-config reset
