Command reference
volume efficiency revert-to
Reverts volume efficiency metadata
The volume efficiency revert-to command reverts the format of volume efficiency metadata for the volume to the given version of ONTAP. This command is not supported on FlexGroup volumes.
-vserver <vserver name> - Vserver Name (privilege: advanced)
This specifies the Vserver on which the volume is located.
{ -volume <volume name> - Volume Name (privilege: advanced)
This specifies the name of the volume for which volume efficiency metadata needs to be reverted.
| -path </vol/volume> - Volume Path (privilege: advanced) }
This specifies the volume path for which volume efficiency metadata needs to be reverted.
[-version <revert version>] - Revert to Version (privilege: advanced)
Specifies the version of ONTAP to which the volume efficiency metadata needs to be formatted.
[-d, -delete {true|false}] - Delete Existing Metafile on Revert (privilege: advanced)
If set to true , this parameter specifies that the volume efficiency metadata be deleted instead of reverting its format. By default this parameter is set to false .
[-c, -clean-up {true|false}] - Delete Previously Downgraded Metafiles (privilege: advanced)
If set to true , this parameter specifies that the volume efficiency metadata already reverted using volume efficiency revert-to ` be deleted. By default this parameter is set to `false .
[-revert-adaptive-compression {true|false}] - Downgrade to minor version (privilege: advanced)
If set to true , this parameter specifies that the volume efficiency metadata needs to be reverted to a minor version of ONTAP. By default this parameter is set to false .
[-check-snapshot {true|false}] - Revert ignore snapshots (privilege: advanced)
If set to false , this parameter specifies that the volume efficiency revert will not check for snapshots created by previous releases of ONTAP. By default this parameter is set to true .
The following examples reverts volume efficiency metadata on a volume named vol1 located in vserver vs1 to version 9.8.
cluster1::*> volume efficiency revert-to -vserver vs1 -volume vol1 -version 9.8
cluster1::*> volume efficiency revert-to -vserver vs1 -path /vol/vol1 -version 9.8
