volume encryption rekey start
Start a volume encryption rekey operation
The volume encryption rekey start command changes the encryption key of a volume.
-vserver <vserver name>- Vserver Name-
This parameter specifies the Vserver on which the volume is located.
-volume <volume name>- Volume Name-
This parameter specifies the name of the volume for which the rekey operation is being started.
[-ignore-warning {true|false}]- Ignore Warning for Rekey Start-
If this parameter is set, the command ignores the confirmation message.
