Command reference
vserver cifs connection show
Displays established CIFS connections
The vserver cifs connection show command displays information about established CIFS connections.
{ [-fields <fieldname>,…​]
Use this parameter to display only the specified fields
| [-instance ] }
[-node {<nodename>|local}] - Node
Use this parameter to display information about CIFS connections on the specified node.
[-vserver <vserver name>] - Vserver
Use this parameter to display information about CIFS connections on the specified CIFS-enabled SVM.
[-connection-id <integer>] - Connection ID
Use this parameter to display information about CIFS connections that match the specified connection ID.
[-session-id <integer>,…​] - Session ID
Use this parameter to display information about CIFS connections that match the specified session ID.
[-workstation-ip <IP Address>] - Workstation IP Address
Use this parameter to display information about CIFS connections that are established through the specified data LIF IP address.
[-workstation-port <integer>] - Workstation Port Number
Use this parameter to display information about CIFS connections that are opened from the specified Port number.
[-lif-ip <IP Address>] - Incoming Data LIF IP Address
Use this parameter to display information about CIFS connections that are opened from the specified IP address.
[-network-context-id <integer>] - Network Context ID (privilege: advanced)
Use this parameter to display information about CIFS connections that match the specified network context ID.
The following example displays information about all CIFS connections:
cluster1::> vserver cifs connection show
Node:    node1
Vserver: vs1
Connection Session                           Workstation
ID         IDs                Workstation IP Port        LIF IP
127834     1,2                172.17.193.172 15536       10.53.50.42
The following example displays information about a CIFS connection at advanced privilege level:
cluster1::*> vserver cifs connection show
Node:    node1
Vserver: vs1
Connection Session                           Workstation             Network
ID         IDs                Workstation IP Port        LIF IP      Context ID
127834     1,2                172.17.193.172 15536       10.53.50.42 2
The following example displays information about a CIFS connection with session-id 1:
cluster1::*> vserver cifs connection show -session-id 1 -instance
Vserver: vs1
Node: node1
               Connection ID: 127834
                  Session ID: 1
      Workstation IP Address: 172.17.193.172
     Workstation Port Number: 15536
Incoming Data LIF IP Address: 10.53.50.42
          Network Context ID: 2
