Command reference
vserver consistency-group snapshot modify-snaplock-expiry-time
Modify SnapLock expiry time of a consistency group snapshot
The vserver consistency-group snapshot modify-snaplock-expiry-time command modifies a snapshot of a specified consistency group.
-vserver <Vserver Name> - Vserver Name
This parameter specifies the Vserver that contains the consistency group on which the snapshot is to be modified.
-consistency-group <text> - Consistency Group Name
This parameter specifies the consistency group where a snapshot is to be modified.
-snapshot <snapshot name> - Snapshot Name
This parameter specifies the name of the snapshot that is to be modified.
-expiry-time {MM/DD/YYYY HH:MM:SS [{+|-}hh:mm] | infinite} - SnapLock Expiry Time
Specifies the new SnapLock expiry that is applied to snapshot locked by SnapLock.
If this option value is infinite , then a retention period that never expires is applied to the snapshot.
The following example extends the retention period of a snapshot snap1 to "03/03/2020 00:00:00" :
cluster1::> vserver consistency-group snapshot modify-snaplock-expiry-time -vserver vs1 -consistency-group dst -snapshot s1 -expiry-time "03/03/2020 00:00:00"
    cluster1::>
The following example extends the retention period of a snapshot snap2 to infinite :
cluster1::> vserver consistency-group snapshot modify-snaplock-expiry-time -vserver vs1 -consistency-group dst -snapshot s2 -expiry-time infinite
    cluster1::>
cluster1::> vserver consistency-group snapshot show -vserver vs1 -fields snaplock-expiry-time
                (vserver consistency-group snapshot show)
                vserver consistency-group parent-consistency-group snapshot snaplock-expiry-time
                vs1     dst               -                        s1       3/3/2020 00:00:00 +05:30
                vs1     dst               -                        s2       infinite
