Command reference
vserver fpolicy disable
Disable a policy
The vserver fpolicy disable command disables an FPolicy policy for the specified Vserver.
-vserver <Vserver Name> - Vserver
This parameter specifies the name of the Vserver on which you want to disable an FPolicy policy.
-policy-name <Policy name> - Policy
This parameter specifies the name of the FPolicy policy you want to disable.
The following command disables an FPolicy policy.
cluster1::> vserver fpolicy show
Vserver                 Policy Name                    Sequence  Status Engine
vs1.example.com         vs1_pol                               -  off    native
vs2.example.com         vs2_pol                               5  on     external
2 entries were displayed.
cluster1::> vserver fpolicy disable -vserver vs2.example.com -policy-name vs2_pol
vs2.example.com         vs2_pol                               -  off      external
